No, it is a CD4016B "B" not "8"
Please take Alain's advice and get a qualified tech involved. If you can't recognize the correct part numbers then you have no business being inside the thing.
Moog Source no Ramp wave VCO 1
Re: Moog Source no Ramp wave VCO 1
- thealien666
U32 would be a CD4016BE (not 8E).
Similar to this:
Have you tested the synth since you put it back in its socket properly ? Maybe it was just not inserted properly ?
P.S. Oops, burned by MC...
Similar to this:
ok, found the part via Mouser for 52 cents, will see if replacing this works.
ok, replaced cd4016BE with the new chip from mouser. worked with the new chip, but didn't fix the problem, so it obviously wasn't that. any other ideas before I take it to a tech?
